Ga door naar hoofdinhoud
Samsung SGH-X105 Earpiece Speaker Replacement
Wat je nodig hebt
  1. Samsung SGH-X105 Earpiece Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Earpiece Speaker Replacement: stap 2, afbeelding 1 van 3 Samsung SGH-X105 Earpiece Speaker Replacement: stap 2, afbeelding 2 van 3 Samsung SGH-X105 Earpiece Speaker Replacement: stap 2, afbeelding 3 van 3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Earpiece Speaker Replacement, Front & Back Panels: stap 3, afbeelding 1 van 1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Earpiece Speaker Replacement: stap 4, afbeelding 1 van 3 Samsung SGH-X105 Earpiece Speaker Replacement: stap 4, afbeelding 2 van 3 Samsung SGH-X105 Earpiece Speaker Replacement: stap 4, afbeelding 3 van 3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Earpiece Speaker Replacement: stap 5, afbeelding 1 van 2 Samsung SGH-X105 Earpiece Speaker Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Earpiece Speaker Replacement, Earpiece Speaker: stap 6, afbeelding 1 van 1
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Earpiece Speaker Replacement: stap 7, afbeelding 1 van 3 Samsung SGH-X105 Earpiece Speaker Replacement: stap 7, afbeelding 2 van 3 Samsung SGH-X105 Earpiece Speaker Replacement: stap 7, afbeelding 3 van 3
    • Using a SL 1.5 flathead screwdriver (or any small prying tool), pry the speaker from the plastic front cover.
    • The earpiece speaker is magnetic so you can use a magnet to remove the earpiece speaker from the plastic front cover once loosened.
    • You can apply your own adhesive to secure your replaced speaker if desired during reassembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chris Lao
16 Reputatie
1 Handleiding geschreven
Cal Poly, Team 28-29, Regan Spring 2010 Lid van Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
4 Leden
12 handleidingen geschreven
Één opmerking
Where can I get a replacement speaker?
NickyPhils - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,960
