Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate SIM card
Slide SIM card down and gently pull out of the card slot
Gereedschap gebruikt in deze stap:Magnetic Project Mat$19.95-
Locate the six (4mm) screws on the back casing of the phone.
Unscrew each one using a phillips head #000 screwdriver.
Place screws on magnetic mat.
Starting at the top of the phone, carefully insert plastic opening device into the seam.
Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
Locate the connection point of black wire running from the microphone to the motherboard.
Carefully disconnect the gold connector from the motherboard using tweezers.
Locate the red connector at the top of the motherboard.
Carefully lift and remove the connector from the motherboard using tweezers.
Locate the gold connector that connects the screen to the motherboard.
Carefully disconnect the connector from the motherboard using tweezers.
Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
Lift the motherboard from the cell phone.
