Ga door naar hoofdinhoud
Samsung SGH-E317 Motherboard Replacement
Wat je nodig hebt
  1. Samsung SGH-E317 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. Samsung SGH-E317 Motherboard Replacement, Motherboard: stap 2, afbeelding 1 van 1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. Samsung SGH-E317 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the rubber screw cover using your fingernail.
  4. Samsung SGH-E317 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. Samsung SGH-E317 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. Samsung SGH-E317 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • With the back panel removed, the motherboard should be fully exposed.
  7. Samsung SGH-E317 Motherboard Replacement: stap 7, afbeelding 1 van 2 Samsung SGH-E317 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. Samsung SGH-E317 Motherboard Replacement: stap 8, afbeelding 1 van 2 Samsung SGH-E317 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. Samsung SGH-E317 Motherboard Replacement: stap 9, afbeelding 1 van 2 Samsung SGH-E317 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
Conclusie
Chris Dimler
124 Reputatie
1 Handleiding geschreven
Cal Poly, Team 11-23, Maness Winter 2011 Lid van Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 15
Altijd: 1,395
