Ga door naar hoofdinhoud
Samsung SGH-A237 Keypad Replacement
Wat je nodig hebt
  1. Samsung SGH-A237 Keypad Replacement, Keypad: stap 1, afbeelding 1 van 2 Samsung SGH-A237 Keypad Replacement, Keypad: stap 1, afbeelding 2 van 2
    • Place phone face down so battery cover is showing.
  2. Samsung SGH-A237 Keypad Replacement: stap 2, afbeelding 1 van 2 Samsung SGH-A237 Keypad Replacement: stap 2, afbeelding 2 van 2
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Samsung SGH-A237 Keypad Replacement: stap 3, afbeelding 1 van 2 Samsung SGH-A237 Keypad Replacement: stap 3, afbeelding 2 van 2
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Keypad Replacement: stap 4, afbeelding 1 van 3 Samsung SGH-A237 Keypad Replacement: stap 4, afbeelding 2 van 3 Samsung SGH-A237 Keypad Replacement: stap 4, afbeelding 3 van 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  5. Samsung SGH-A237 Keypad Replacement: stap 5, afbeelding 1 van 1
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  6. Samsung SGH-A237 Keypad Replacement: stap 6, afbeelding 1 van 2 Samsung SGH-A237 Keypad Replacement: stap 6, afbeelding 2 van 2
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  7. Samsung SGH-A237 Keypad Replacement: stap 7, afbeelding 1 van 1
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
Conclusie
Shawn
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 29-81, Johann Spring 2010 Lid van Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Leden
8 handleidingen geschreven
Één opmerking
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,303
