Ga door naar hoofdinhoud
Samsung SGH-A137 Keypad Replacement
Wat je nodig hebt
  1. Samsung SGH-A137 Keypad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use your thumbs to pull down on the back cover to remove it and expose the battery.
  2. Samsung SGH-A137 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Locate the indent in the case below the battery. (see red square)
    • Place your finger at the indent and pull up on the battery to remove it.
  3. Samsung SGH-A137 Keypad Replacement, Motherboard: stap 3, afbeelding 1 van 3 Samsung SGH-A137 Keypad Replacement, Motherboard: stap 3, afbeelding 2 van 3 Samsung SGH-A137 Keypad Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Locate the 4 screw holes and remove the 0.4 mm Phillips head screws using a #000 Phillips head screwdriver. (See red circles)
  4. Samsung SGH-A137 Keypad Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry open the back of the phone at the seam.
    • Carefully work the tool all the way around the opening while prying up to avoid breaking the plastic retaining clips.
  5. Samsung SGH-A137 Keypad Replacement: stap 5, afbeelding 1 van 2 Samsung SGH-A137 Keypad Replacement: stap 5, afbeelding 2 van 2
    • Smaller press-fit connectors may require a simple flick with a plastic opening tool or spudger.
    • Place the flat edge of a spudger under the edge of the press-fit connector and , gently pry the connector straight up from its socket. (Highlighted by the red square)
  6. Samsung SGH-A137 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry up the motherboard.
    • You might need to pry from several different locations to get the motherboard loose enough to remove.
  7. Samsung SGH-A137 Keypad Replacement, Keypad: stap 7, afbeelding 1 van 1
    • Gently push the keypad out toward the back.
  8. Samsung SGH-A137 Keypad Replacement: stap 8, afbeelding 1 van 1
    • Replace the defective keypad and reassemble the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Gayle Eberhardt Mitchell
652 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 310
