Ga door naar hoofdinhoud
Samsung SCH-U340 Top Casing Replacement
Wat je nodig hebt
  1. Samsung SCH-U340 Top Casing Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Top Casing Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Top Casing Replacement: stap 3, afbeelding 1 van 1
    • Set the battery aside.
  4. Samsung SCH-U340 Top Casing Replacement, Top Casing: stap 4, afbeelding 1 van 1
    • The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs.
    • First, remove the plastic plugs covering the screws with a spudger.
  5. Samsung SCH-U340 Top Casing Replacement: stap 5, afbeelding 1 van 1
    • Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver.
    • The screws will need to be pried out after unscrewing them due to their size.
    • Take care not to lose the screws as they are small and have a tendency to roll.
  6. Samsung SCH-U340 Top Casing Replacement: stap 6, afbeelding 1 van 1
    • The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
    • To begin removing the outer cover, start by prying the large tab up with a flat object.
    • See next slide for details for smaller tabs.
  7. Samsung SCH-U340 Top Casing Replacement: stap 7, afbeelding 1 van 1
    • Continue to pry each smaller tab up, taking care not to break the tabs.
    • If disaster strikes and a tab is broken, the outer casing can still be put back on assuming the majority of the tabs are still intact.
  8. Samsung SCH-U340 Top Casing Replacement: stap 8, afbeelding 1 van 1
    • After the last tab is removed, tug gently on the outer casing to remove it.
    • Don't pull too hard, or you may damage the wires connected to the speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Anish Sambamurthy
31 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-21, Maness Winter 2010 Lid van Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 2,778
