Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the cell phone so that the back side is facing you.
Press the upper indent and slide the back cover down.
Pull the battery up from indent at the bottom and slide it out.
The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
Use a spudger to pry the back assembly off of the device.
