Ga door naar hoofdinhoud
Samsung SCH-A950 Keyboard Replacement
Wat je nodig hebt
  1. Samsung SCH-A950 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung SCH-A950 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  2. Samsung SCH-A950 Keyboard Replacement, Volume and Camera Buttons: stap 2, afbeelding 1 van 1
    • Remove the four Phillips #00 screws underneath the battery.
  3. Samsung SCH-A950 Keyboard Replacement: stap 3, afbeelding 1 van 2 Samsung SCH-A950 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Pull open the earphone tab and the Trans Flash tab using your fingers.
  4. Samsung SCH-A950 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
    • Slide the casing slightly forward towards the top of the phone to remove.
  5. Samsung SCH-A950 Keyboard Replacement: stap 5, afbeelding 1 van 3 Samsung SCH-A950 Keyboard Replacement: stap 5, afbeelding 2 van 3 Samsung SCH-A950 Keyboard Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using tweezers or your fingers, lift off buttons from logic board.
    • The buttons can be replaced if needed.
  6. Samsung SCH-A950 Keyboard Replacement, Speakers: stap 6, afbeelding 1 van 2 Samsung SCH-A950 Keyboard Replacement, Speakers: stap 6, afbeelding 2 van 2
    • Use tweezers to peel back the sticker on the backside of the speaker to reveal a screw that holds the speaker in place.
    • Using a phillips #00 screwdriver, remove the screw holding the speaker. On each side.
  7. Samsung SCH-A950 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Using the tweezers, grasp the plastic connector that connects the speaker to the logic board and pull the connector off of the logic board.
  8. Samsung SCH-A950 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Push the speaker out of the phone using the spudger.
  9. Samsung SCH-A950 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the speaker from the decorative housing by pulling on the wires.
    • The speaker can be replaced if needed.
  10. Samsung SCH-A950 Keyboard Replacement, Logic Board: stap 10, afbeelding 1 van 1
    • Using a plastic opening tool, disconnect the display cable from the motherboard.
  11. Samsung SCH-A950 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Use a plastic opening tool to pry the motherboard away from the phone housing at the tabs on both sides of the phone at the pictured location. Some force may be required.
  12. Samsung SCH-A950 Keyboard Replacement: stap 12, afbeelding 1 van 1
    • The logic board will pop out.
    • The logic board can be replaced if needed.
  13. Samsung SCH-A950 Keyboard Replacement, Keyboard: stap 13, afbeelding 1 van 2 Samsung SCH-A950 Keyboard Replacement, Keyboard: stap 13, afbeelding 2 van 2
    • Once the logic board has been removed, the keyboard is exposed and can be removed by simply lifting the keyboard out of the phone housing.
    • The keyboard can be replaced if needed.
Conclusie
Alan Cook
44 Reputatie
3 handleidingen geschreven
Cal Poly, Team 11-5, Forte Winter 2010 Lid van Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 12
Altijd: 1,552
