Ga door naar hoofdinhoud
Samsung SCH-A670 Screen Replacement
Wat je nodig hebt
  1. Samsung SCH-A670 Screen Replacement, Battery Cover: stap 1, afbeelding 1 van 1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Screen Replacement, Battery: stap 2, afbeelding 1 van 1
    • Remove the battery.
  3. Samsung SCH-A670 Screen Replacement, Logic Board: stap 3, afbeelding 1 van 1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Screen Replacement: stap 4, afbeelding 1 van 1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Screen Replacement: stap 5, afbeelding 1 van 1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Screen Replacement: stap 6, afbeelding 1 van 2 Samsung SCH-A670 Screen Replacement: stap 6, afbeelding 2 van 2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Screen Replacement: stap 7, afbeelding 1 van 1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Screen Replacement: stap 8, afbeelding 1 van 1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Screen Replacement, Keypad: stap 9, afbeelding 1 van 1
    • Once the logic board has been removed, peel the keypad up.
  10. Samsung SCH-A670 Screen Replacement, Keypad Housing: stap 10, afbeelding 1 van 2 Samsung SCH-A670 Screen Replacement, Keypad Housing: stap 10, afbeelding 2 van 2
    • When using a spudger the keypad housing comes off quite easily, although it may be necessary to guide the ribbon cable through the slot in the housing.
  11. Samsung SCH-A670 Screen Replacement, Screen Casing: stap 11, afbeelding 1 van 1
    • Remove screws with #0 Phillips screwdriver.
  12. Samsung SCH-A670 Screen Replacement: stap 12, afbeelding 1 van 1
    • Carefully pry apart the casing with the spudger tool.
  13. Samsung SCH-A670 Screen Replacement, Screen: stap 13, afbeelding 1 van 1
    • Use the spudger to carefully pry off the speaker.
  14. Samsung SCH-A670 Screen Replacement: stap 14, afbeelding 1 van 1
    • Carefully pry off the ringer with the spudger.
  15. Samsung SCH-A670 Screen Replacement: stap 15, afbeelding 1 van 1
    • Carefully pry off the screen with the spudger.
Conclusie
Nathan Brink
19 Reputatie
7 handleidingen geschreven
Cal Poly, Team 34-59, Forte Spring 2010 Lid van Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 3,459
