Wat je nodig hebt
With the phone upright and folded shut, locate the two silver tabs at the top of the screen.
Using one hand, pinch the two tabs inward, and use your other hand to slide the front cover of the screen off of the phone.
With the phone upright, locate the small piece of electrical tape on the right side of the screen. Remove it and place it where you won't lose it.
Slip the plastic tool behind the outside display where the tape used to be. Peel away the screen from its white backing.
Continue to peel away the screen until it becomes fully detached. Attach the new screen.
