Ga door naar hoofdinhoud
Samsung SCH-8500 Volume Button Replacement
Wat je nodig hebt
  1. Samsung SCH-8500 Volume Button Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung SCH-8500 Volume Button Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung SCH-8500 Volume Button Replacement, Battery: stap 1, afbeelding 3 van 3
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Samsung SCH-8500 Volume Button Replacement, Back Case: stap 2, afbeelding 1 van 3 Samsung SCH-8500 Volume Button Replacement, Back Case: stap 2, afbeelding 2 van 3 Samsung SCH-8500 Volume Button Replacement, Back Case: stap 2, afbeelding 3 van 3
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
  3. Samsung SCH-8500 Volume Button Replacement, Volume Button: stap 3, afbeelding 1 van 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: stap 3, afbeelding 2 van 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: stap 3, afbeelding 3 van 3
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
Conclusie
Will Gunter
1 Reputatie
4 handleidingen geschreven
Clemson, Team 14-6, Benson Fall 2012 Lid van Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 212
