Ga door naar hoofdinhoud
Samsung SCH-8500 Keypad Replacement
Wat je nodig hebt
  1. Samsung SCH-8500 Keypad Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung SCH-8500 Keypad Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung SCH-8500 Keypad Replacement, Battery: stap 1, afbeelding 3 van 3
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Samsung SCH-8500 Keypad Replacement, Back Case: stap 2, afbeelding 1 van 3 Samsung SCH-8500 Keypad Replacement, Back Case: stap 2, afbeelding 2 van 3 Samsung SCH-8500 Keypad Replacement, Back Case: stap 2, afbeelding 3 van 3
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
  3. Samsung SCH-8500 Keypad Replacement, Volume Button: stap 3, afbeelding 1 van 3 Samsung SCH-8500 Keypad Replacement, Volume Button: stap 3, afbeelding 2 van 3 Samsung SCH-8500 Keypad Replacement, Volume Button: stap 3, afbeelding 3 van 3
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
  4. Samsung SCH-8500 Keypad Replacement, Keypad: stap 4, afbeelding 1 van 3 Samsung SCH-8500 Keypad Replacement, Keypad: stap 4, afbeelding 2 van 3 Samsung SCH-8500 Keypad Replacement, Keypad: stap 4, afbeelding 3 van 3
    • The circuit board is hardwired to other components in the phone and cannot be completely removed. Take extreme precaution when performing this step as to not damage the circuitry or the wiring.
    • Lift the circuit board up slightly.
    • With the circuit board lifted, remove the plastic keypad and place to the side.
Conclusie
Will Gunter
1 Reputatie
4 handleidingen geschreven
Clemson, Team 14-6, Benson Fall 2012 Lid van Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 259
