Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew the eight 4mm screws using the Phillips #000 screwdriver.
Unplug the cord connecting the LCD section of the device.
Remove the left face of the device.
Remove the top face by removing the three 4mm screws using a Phillips #000 screwdriver.
After removing the body of the device, unscrew the two 3.5mm Phillips #000 screws holding the battery compartment in place.
Remove the battery compartment.
Remove the three 3.5mm Phillips #000 screws on the metal part from the lens component.
Remove the motherboard from the lens.
Remove the lens from the lens assembly.
