Ga door naar hoofdinhoud
Samsung S860 Logic Board Replacement
Wat je nodig hebt
  1. Samsung S860 Logic Board Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung S860 Logic Board Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung S860 Logic Board Replacement, Battery: stap 1, afbeelding 3 van 3
    • With the camera facing LCD side up, slide the battery compartment lid to the right.
    • Remove the old batteries.
  2. Samsung S860 Logic Board Replacement, LCD Screen: stap 2, afbeelding 1 van 2 Samsung S860 Logic Board Replacement, LCD Screen: stap 2, afbeelding 2 van 2
    • Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
  3. Samsung S860 Logic Board Replacement: stap 3, afbeelding 1 van 1
    • Slide open the battery compartment cover before removing the exterior covers of the camera.
  4. Samsung S860 Logic Board Replacement: stap 4, afbeelding 1 van 3 Samsung S860 Logic Board Replacement: stap 4, afbeelding 2 van 3 Samsung S860 Logic Board Replacement: stap 4, afbeelding 3 van 3
    • Carefully pull the back case (the side showing the LCD screen) away from the front half.
    • There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
    • Turn the camera around to the front (the lens side). Carefully remove the front case.
    • There are also clips on the lens' side as well, so do not be afraid to use force.
  5. Samsung S860 Logic Board Replacement: stap 5, afbeelding 1 van 2 Samsung S860 Logic Board Replacement: stap 5, afbeelding 2 van 2
    • Position the camera so the LCD screen is facing you.
    • Remove the LCD screen from the screen plate.
    • Replace the broken LCD screen with the functioning LCD screen.
  6. Samsung S860 Logic Board Replacement, Logic Board: stap 6, afbeelding 1 van 2 Samsung S860 Logic Board Replacement, Logic Board: stap 6, afbeelding 2 van 2
    • The screws should be 4.3 mm in length.
    • Save them for putting the camera back together.
  7. Samsung S860 Logic Board Replacement: stap 7, afbeelding 1 van 1
    • Turn the bottom edge of the camera towards you.
    • Slide open the battery chamber.
    • This must be done to remove the exterior covers of the camera.
  8. Samsung S860 Logic Board Replacement: stap 8, afbeelding 1 van 3 Samsung S860 Logic Board Replacement: stap 8, afbeelding 2 van 3 Samsung S860 Logic Board Replacement: stap 8, afbeelding 3 van 3
    • Carefully pull the back of the camera (the LCD screen side) away from the front.
    • Turn the camera to the front (the flash side). Carefully remove.
    • There are clips on this side as well. Again, do not be afraid to use force.
  9. Samsung S860 Logic Board Replacement: stap 9, afbeelding 1 van 2 Samsung S860 Logic Board Replacement: stap 9, afbeelding 2 van 2
    • Orient the camera so the LCD screen is facing you.
    • Remove any tape holding it down, and then lift the LCD screen from the screen plate.
    • Lift the hinged lip where the ribbon enters the connector. Remove the ribbon from the logic board by pulling it gently away from the logic board.
  10. Samsung S860 Logic Board Replacement: stap 10, afbeelding 1 van 1
    • Remove all screws from the screen plate, using a #00 Philips screwdriver.
    • The screws should be 4.5 mm in length.
    • Separate the screen plate and logic board.
  11. Samsung S860 Logic Board Replacement: stap 11, afbeelding 1 van 1
    • There is another ribbon attached to the logic board. It is located on the upper left edge of the logic board.
    • Similar to the other ribbon, remove by gently pulling in the opposite direction of the logic board. The "ears" on the cable can be used to help pull it free.
  12. Samsung S860 Logic Board Replacement: stap 12, afbeelding 1 van 1
    • Using a #00 Philips screwdriver, unscrew the screws connecting the logic board to the camera.
    • You should be removing three 3.32 mm long screws.
    • Separate the logic board and the core of the camera.
  13. Samsung S860 Logic Board Replacement: stap 13, afbeelding 1 van 1
    • To separate the logic board from the camera, carefully pull the logic board away from the camera.
    • Be careful not to damage the battery compartment. The battery sensors are attached to the logic board, so be gentle.
    • The USB connector is going to want to hang up on the housing, but once you have that free, the battery leads will slide out relatively easily.
Conclusie
Kando Ogunrinola
185 Reputatie
3 handleidingen geschreven
Cal Poly, Team 33-72, Johann Spring 2010 Lid van Cal Poly, Team 33-72, Johann Spring 2010
CPSU-JOHANN-S10S33G72
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 9,123
