Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
You will take the camera apart in order to replace the damaged LCD screen and restore functionality.
Wat je nodig hebt
Remove all screws along the edges of the camera, using a #00 Phillips screwdriver.
Carefully pull the back case (the side showing the LCD screen) away from the front half.
There are clips securing the top of the back case. Do not be afraid to use the proper amount of force to remove the back case.
Turn the camera around to the front (the lens side). Carefully remove the front case.
There are also clips on the lens' side as well, so do not be afraid to use force.
3 andere personen hebben deze handleiding voltooid.
