Inleiding
The battery cover can break off fairly easily if you're not careful, as it is attached by only a single hinge. This guide will show you how to replace it.
Wat je nodig hebt
Placing your thumb on the battery cover, push outwards, away from the camera in the direction the arrow is pointing. If done correctly when it's completely unhooked, the latch will open.
Locate and remove the six 4mm screws on the sides of the camera.
Using the pointed end of the Spudger, push the metal pin out of the hinge as far as it will go (this will typically be halfway).
