Door de gemeenschap gemaakte handleiding
Deze handleiding is gemaakt door een enthousiasteling uit de gemeenschap, en niet door de iFixit-stafleden.
Inleiding
Ga naar stap 1 ↓This will show how to change a broken display. The display is readily available at many different sources and should cost no more than $15. The repair is quick and does not require any special skills, like soldering etc.
Wat je nodig hebt
Onderdelen
Gereedschap
Here is my Samsung S630. Nice little camera with just one flaw. The LCD display was broken.
This particular camera has some Kapton tape holding the cable to the logic board. Gently remove it from the board only.
Open the locking tab on the PCB connector and remove the cable. This will separate the LCD from the board.
This is what the logic board looks like without the frame and the LCD.
3 andere personen hebben deze handleiding voltooid.
