Ga door naar hoofdinhoud
Samsung Rogue Camera Replacement
Wat je nodig hebt
  1. Samsung Rogue Camera Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Rogue Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before disassembling your Samsung Rogue, make sure it is powered off.
    • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
    Vraag FixBot
  2. Samsung Rogue Camera Replacement: stap 2, afbeelding 1 van 2 Samsung Rogue Camera Replacement: stap 2, afbeelding 2 van 2
    • You can now remove the battery by prying it up with your finger.
    Vraag FixBot
  3. Samsung Rogue Camera Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
    Vraag FixBot
  4. Samsung Rogue Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the five 3.4mm Philips screws securing the backing of the phone.
    Vraag FixBot
  5. Samsung Rogue Camera Replacement: stap 5, afbeelding 1 van 3 Samsung Rogue Camera Replacement: stap 5, afbeelding 2 van 3 Samsung Rogue Camera Replacement: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool to carefully pry off the back cover.
    • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
    • Be careful to not drop the volume changing piece, for it can easily slip out.
    Vraag FixBot
  6. Samsung Rogue Camera Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 3.45 mm Philips screws below the white sticker.
    Vraag FixBot
  7. Samsung Rogue Camera Replacement: stap 7, afbeelding 1 van 2 Samsung Rogue Camera Replacement: stap 7, afbeelding 2 van 2
    • Carefully lift the motherboard up from the bottom edge.
    • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
    Vraag FixBot
  8. Samsung Rogue Camera Replacement: stap 8, afbeelding 1 van 2 Samsung Rogue Camera Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to disconnect the film from the motherboard.
    Vraag FixBot
  9. Samsung Rogue Camera Replacement, Speaker/Antenna: stap 9, afbeelding 1 van 1
    • On the underside of the motherboard, remove the single 3.3mm Philips screw.
    Vraag FixBot
  10. Samsung Rogue Camera Replacement: stap 10, afbeelding 1 van 3 Samsung Rogue Camera Replacement: stap 10, afbeelding 2 van 3 Samsung Rogue Camera Replacement: stap 10, afbeelding 3 van 3
    • The speaker and the antenna are both connected on the same black piece.
    • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
    • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
    • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
    Vraag FixBot
  11. Samsung Rogue Camera Replacement, Camera: stap 11, afbeelding 1 van 3 Samsung Rogue Camera Replacement, Camera: stap 11, afbeelding 2 van 3 Samsung Rogue Camera Replacement, Camera: stap 11, afbeelding 3 van 3
    • With two fingers carefully detach the camera from the motherboard by lifting straight up.
    • Do not pick it up by the camera itself. Handle the little black box it is attached to instead.
    Vraag FixBot
Conclusie
Viktoria Mikoultchik
25 Reputatie
7 handleidingen geschreven
Cal Poly, Team 7-32, Maness Spring 2012 Lid van Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 53
Altijd: 476
