Ga door naar hoofdinhoud
Samsung Rant Rear Case Replacement
Wat je nodig hebt
  1. Samsung Rant Rear Case Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Rear Case Replacement, Rear Case: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  3. Samsung Rant Rear Case Replacement: stap 3, afbeelding 1 van 1
    • Gently separate the rear case from the front case.
Conclusie
Denise Cooper
31 Reputatie
3 handleidingen geschreven
James Madison, Team 1-6, Allen Fall 2011 Lid van James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,164
