Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
To remove the battery in the Samsung Rant, you must first remove the back cover. Then the battery will be accessible for removal.
Turn the phone over in the palm of your hand, with the screen facing down.
While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
You should now be able to lift the plate completely off of the phone.
*New Battery information: Standard Lithium Ion (Li-Ion); Talk time: 5.6 hours max. (336 minutes)
Één opmerking
*New batteries need to be charged before use.
*You should charge your battery in an area that is free of moisture, extreme cold or extreme heat.
*Refer to the repair manual (Samsung Rant Device page above) for information on purchasing a battery and battery life.
