Ga door naar hoofdinhoud
Samsung Rant Battery Replacement
  1. Samsung Rant Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Battery Replacement, Battery: stap 2, afbeelding 1 van 1
    • Carefully remove the battery from the phone.
Conclusie
*New Battery information: Standard Lithium Ion (Li-Ion); Talk time: 5.6 hours max. (336 minutes)
Todd
1 Reputatie
1 Handleiding geschreven
James Madison, Team 1-6, Allen Fall 2011 Lid van James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Leden
12 handleidingen geschreven
1Gids Commentaar
*New batteries need to be charged before use.
*You should charge your battery in an area that is free of moisture, extreme cold or extreme heat.
*Refer to the repair manual (Samsung Rant Device page above) for information on purchasing a battery and battery life.
Denise Cooper - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 44
Altijd: 1,654
