Inleiding
In this guide, we will be replacing the USB module of the speaker, which also houses the button used in pairing the speaker for Wi-Fi capabilities. You will need to remove the bottom cover, unplug the connector from the motherboard to it, and remove it from the speaker assembly.
Wat je nodig hebt
Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
Remove the four 10mm long screws with the Phillips #1 screwdriver.
Één andere persoon heeft deze handleiding voltooid.
