Inleiding
This guide will walk you through the process of removing the bottom of the speaker, the outer shell, and the motherboard to access the subwoofer for removal.
Wat je nodig hebt
Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
Remove the four 10mm long screws with the Phillips #1 screwdriver.
Remove the two 12mm long screws with the Phillips #1 screwdriver.
Unplug white plug connected to the green circuit board.
Één andere persoon heeft deze handleiding voltooid.
