Ga door naar hoofdinhoud
Samsung Propel Motherboard Replacement
Wat je nodig hebt
  1. Samsung Propel Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back panel of the phone.
  2. Samsung Propel Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the old battery and replace with the new one.
  3. Samsung Propel Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 1
    • Use a flat-head screwdriver to remove the back lid.
  4. Samsung Propel Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Locate the six screws and remove them with a Phillips #00 Screwdriver.
    • Insert the flat-head screwdriver into the crevice.
    • Slide and dislodge the snap-ons that are beneath the crevice.
    • Remove the back frame of the device.
  5. Samsung Propel Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Locate and remove the six screws with a Phillips #00 Screwdriver.
    • Separate the black middle frame from the front frame.
    • Be careful not to tear the phone bus.
  6. Samsung Propel Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Locate and remove the four screws with a Phillips #00 Screwdriver.
    • Slide the flat-head screwdriver and dislodge the snap-ons beneath the crevice.
    • Be careful not to rip the band.
  7. Samsung Propel Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use your hands to remove both the phone buses from the linkages and remove the motherboard.
Conclusie
Minh
201 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 1-3, Nelson Spring 2011 Lid van CSU Los Angeles, Team 1-3, Nelson Spring 2011
CSULA-NELSON-S11S1G3
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,789
