Ga door naar hoofdinhoud
Samsung Powerbot R9250 Wheel Replacement
Wat je nodig hebt
  1. Samsung Powerbot R9250 Wheel Replacement, Wheel: stap 1, afbeelding 1 van 1
    • Flip the bot onto its side with the wheel you want to remove on top.
  2. Samsung Powerbot R9250 Wheel Replacement: stap 2, afbeelding 1 van 1
    • Remove the round white cap on the outside of the wheel.
  3. Samsung Powerbot R9250 Wheel Replacement: stap 3, afbeelding 1 van 1
    • Next, pry and remove the white casing that runs around the back round part of the bot.
  4. Samsung Powerbot R9250 Wheel Replacement: stap 4, afbeelding 1 van 1
    • Continue until the whole white casing comes off.
  5. Samsung Powerbot R9250 Wheel Replacement: stap 5, afbeelding 1 van 1
    • For the wheel you want to remove, there is a small square opening on outer black protective layer still around the wheel. Locate the screw that is inside the whole. Remove this screw.
  6. Samsung Powerbot R9250 Wheel Replacement: stap 6, afbeelding 1 van 2 Samsung Powerbot R9250 Wheel Replacement: stap 6, afbeelding 2 van 2
    • Pry the black protective layer away from the wheel, and pull the wheel out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ethen Sanchez
552 Reputatie
5 handleidingen geschreven
Cal Poly, Team 10-3, Banghart Winter 2017 Lid van Cal Poly, Team 10-3, Banghart Winter 2017
CPSU-BANGHART-W17S10G3
3 Leden
10 handleidingen geschreven
Één opmerking
Hi Ethen. I've recently replaced both wheel kits on the same model powerbot you are working on in this guide. When I turn it on now it becomes absolutely possessed. Goes much faster than normal and moved erratically. I am wondering if you have ever experienced this or have heard of this.
Cameron Curran - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 2,869
