Inleiding
Replace the right driving wheel of your POWERbot to end movement problems . To resolve the C 03 error code, replace the right driving wheel.
Wat je nodig hebt
Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
Remove the two 1.5 cm screws above the yellow sliding lock tabs.
Remove the two 1.2 cm screws in the brush compartment.
With the spring fully retracted, unhook the spring from the wheel casing.
7 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Where can you find the replacement left driving wheel? are all the model the same?
Very helpful, thank you.
Just beware of the rubber vacuum part and it’s placement after taking apart the vacuum.
