Ga door naar hoofdinhoud
Samsung POWERbot R7070 Power Brush Replacement
  1. Samsung POWERbot R7070 Power Brush Replacement, Brush: stap 1, afbeelding 1 van 1
    • Flip the device over to access the bottom of the vacuum with the brush compartment positioned close to you.
  2. Samsung POWERbot R7070 Power Brush Replacement: stap 2, afbeelding 1 van 1
    • Slide up on the two yellow sliding tabs to unlock the brush compartment.
  3. Samsung POWERbot R7070 Power Brush Replacement: stap 3, afbeelding 1 van 3 Samsung POWERbot R7070 Power Brush Replacement: stap 3, afbeelding 2 van 3 Samsung POWERbot R7070 Power Brush Replacement: stap 3, afbeelding 3 van 3
    • Press down on the outer edge of the brush cover to tilt the brush cover up. Grab the newly exposed inner edge and lift out the brush cover.
  4. Samsung POWERbot R7070 Power Brush Replacement: stap 4, afbeelding 1 van 2 Samsung POWERbot R7070 Power Brush Replacement: stap 4, afbeelding 2 van 2
    • Pull up the left side of the brush and lift out of the brush compartment.
    • When replacing the brush, the square peg on the right end of the brush must be correctly oriented with the square hole on the right end of the brush compartment.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Christine Erdtsieck
439 Reputatie
1 Handleiding geschreven
CSU Fullerton, Team S2-G8, Bruce Fall 2017 Lid van CSU Fullerton, Team S2-G8, Bruce Fall 2017
CSUF-BRUCE-F17S2G8
3 Leden
10 handleidingen geschreven
5 opmerkingen
How often should the power VR 7000 series self cleaning powerbrush be replace?
Kip Williams - Antwoord
Hello, where could I find a replacement brush for this model?
Haitham - Antwoord
Without a part number, I cannot find a replacement brush.
David Williams - Antwoord
Your brush motor is broken and you can't find it?
engine model: RS395 - 2175 metal case,
fixxer - Antwoord
Hi, Can anyone send me some info on a part number and where to get a replacement brush ~ Samsung POWERbot R7070 Power Brush Replacement?
Thanks much
Kokko Walker - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 4,082
