Ga door naar hoofdinhoud
Samsung PL200 SD card Replacement
  1. Samsung PL200 SD card Replacement, SD card: stap 1, afbeelding 1 van 2 Samsung PL200 SD card Replacement, SD card: stap 1, afbeelding 2 van 2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
    • Once opened, the SD card should be visible.
  2. Samsung PL200 SD card Replacement: stap 2, afbeelding 1 van 2 Samsung PL200 SD card Replacement: stap 2, afbeelding 2 van 2
    • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector.
    • This will cause the SD card to raise up enough to allow you to grab it with your fingers.
    • Use your fingers to remove the old SD card.
  3. Samsung PL200 SD card Replacement: stap 3, afbeelding 1 van 2 Samsung PL200 SD card Replacement: stap 3, afbeelding 2 van 2
    • Insert the new SD card into the SD card slot.
    • Make sure to push it down all the way until it clicks and remains flush with battery.
    • Close the battery/SD card compartment.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jacob Presnell
219 Reputatie
2 handleidingen geschreven
Clemson, Team 15-7, Shirley Winter 2015 Lid van Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 295
