Ga door naar hoofdinhoud
Samsung PL200 Battery Replacement
  1. Samsung PL200 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung PL200 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/SD card compartment door. Once opened, the battery should be visible.
  2. Samsung PL200 Battery Replacement: stap 2, afbeelding 1 van 3 Samsung PL200 Battery Replacement: stap 2, afbeelding 2 van 3 Samsung PL200 Battery Replacement: stap 2, afbeelding 3 van 3
    • Once the battery/SD card compartment is opened, in order to remove the battery, you must push the small blue release button.
    • This will release the spring loaded battery.
    • Use your fingers to remove the old battery.
  3. Samsung PL200 Battery Replacement: stap 3, afbeelding 1 van 3 Samsung PL200 Battery Replacement: stap 3, afbeelding 2 van 3 Samsung PL200 Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert the new battery into the battery slot.
    • Push it down with your finger until the blue release switch re-engages over top of the battery.
    • Close the battery/SD card compartment.
Conclusie
After replacing the battery, be sure to connect your charger cable and charge the new battery fully before using it.
Austin Fitzpatrick
110 Reputatie
1 Handleiding geschreven
Clemson, Team 15-7, Shirley Winter 2015 Lid van Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
5 Leden
9 handleidingen geschreven
2 opmerkingen
Is the battery dead? Can Samsung indicate wher new batteries are sold? Camera retailers are rare, these days
Reginald Parker - Antwoord
No-one can find a contact address for Samsung spares. New smartphones, no problem! Thank you for trying. I just have to keep looking! Reg
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 41
Altijd: 1,088
