Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Here is a PL20 that has a broken LCD, as well as some other issues. The repair is straight forward. The only tools used were a Phillips screwdriver and a plastic opening tool, which is optional. This camera was actually fun to work on; it was easy and took no time at all.
Wat je nodig hebt
Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
Remove the battery and the memory card from the device, if so equipped.
Remove the two screws on the left side.
6 andere personen hebben deze handleiding voltooid.
