Ga door naar hoofdinhoud
Inleiding
Here is a PL20 that has a broken LCD, as well as some other issues. The repair is straight forward. The only tools used were a Phillips screwdriver and a plastic opening tool, which is optional. This camera was actually fun to work on; it was easy and took no time at all.
  1. Here is the broken LCD.  The spider crack in the glass, as well as the discoloration of the screen, is clearly visible. Remove the battery and the memory card from the device, if so equipped. Remove the two screws on the left side.
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  3. Remove one screw from the bottom Remove the two screws on the right side. Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  4. Once the back of the case is removed, the LCD becomes immediately visible. Remove the LCD from its holder to gain access to the connector. Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
Conclusie
5 andere personen hebben deze handleiding voltooid.
oldturkey03
586.742 Reputatie
101 handleidingen geschreven
OTS Lid van OTS
Business
1 Lid
127 handleidingen geschreven
Één commentaar
Great help! Screen replaced no problem. Thank you
EE61 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 7
Altijd: 2,966
