Ga door naar hoofdinhoud
Samsung NX1 Back Cover Replacement
Wat je nodig hebt
  1. Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: stap 1, afbeelding 1 van 2 Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: stap 1, afbeelding 2 van 2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Back Cover Replacement: stap 2, afbeelding 1 van 2 Samsung NX1 Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Back Cover Replacement, Back Cover: stap 3, afbeelding 1 van 3 Samsung NX1 Back Cover Replacement, Back Cover: stap 3, afbeelding 2 van 3 Samsung NX1 Back Cover Replacement, Back Cover: stap 3, afbeelding 3 van 3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Back Cover Replacement: stap 4, afbeelding 1 van 2 Samsung NX1 Back Cover Replacement: stap 4, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Back Cover Replacement: stap 6, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Back Cover Replacement: stap 7, afbeelding 1 van 3 Samsung NX1 Back Cover Replacement: stap 7, afbeelding 2 van 3 Samsung NX1 Back Cover Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Back Cover Replacement: stap 8, afbeelding 1 van 2 Samsung NX1 Back Cover Replacement: stap 8, afbeelding 2 van 2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Back Cover Replacement: stap 9, afbeelding 1 van 3 Samsung NX1 Back Cover Replacement: stap 9, afbeelding 2 van 3 Samsung NX1 Back Cover Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hannah Patrick
891 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-4, Leahy Spring 2016 Lid van USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 990
