Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Orient the camera so the button panel and LCD are facing you.
Use a spudger or fingernail to open the battery compartment on the right side of the camera.
Push the blue trapdoor to the left to release the battery, and remove the battery.
Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
Remove the 4 mm Phillips #00 screw hiding in the external flash port.
Remove the four 5 mm Phillips #00 screws from the lens assembly.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Remove the metal lens mount by hand or with tweezers.
Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
Use your hands to slowly pull the front casing away from the camera.
Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
Remove the battery compartment.
Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
Gently remove the sensor mount from the camera case.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hello,
I need to know the exact dimensions of the IR-cut filter in the Samsung NX Mini camera, which should be just above the sensor. Could you possibly give me that information? I need that because I’d like to modify my NX Mini camera and change it into an infrared camera. I have to cut an infrared filter in the right size, before the disassembly of the camera.
Thank you!
