Ga door naar hoofdinhoud
Samsung NX Mini Front Case Replacement
Wat je nodig hebt
  1. Samsung NX Mini Front Case Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung NX Mini Front Case Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung NX Mini Front Case Replacement, Battery: stap 1, afbeelding 3 van 3
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Front Case Replacement: stap 2, afbeelding 1 van 2 Samsung NX Mini Front Case Replacement: stap 2, afbeelding 2 van 2
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini Front Case Replacement, Front Case: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Front Case Replacement: stap 4, afbeelding 1 van 1
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini Front Case Replacement: stap 5, afbeelding 1 van 1
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Front Case Replacement: stap 6, afbeelding 1 van 1
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Front Case Replacement: stap 7, afbeelding 1 van 1
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Front Case Replacement: stap 8, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Front Case Replacement: stap 9, afbeelding 1 van 2 Samsung NX Mini Front Case Replacement: stap 9, afbeelding 2 van 2
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
Conclusie
Kelsea Weber
19.873 Reputatie
32 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 556
