Inleiding
This guide will help a user to remove their device's broken or cracked screen using the steps below.
Wat je nodig hebt
Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
Place the tip of the spudger under the metal caps of the black and grey coaxial connectors and pry upwards to disconnect them.
After they are disconnected, un-thread the coaxial connectors from around the fan.
Bijna klaar!
Conclusie
