Inleiding
This guide covers how to replace the battery for the Samsung Series 5 NP540U3C-A02UB.
The battery provides constant power to the device. This gives the laptop its portability and makes it possible to use the device without being plugged into a wall outlet for long periods of time. The battery may need to be replaced if the device appears to be overheating or has a short battery life. If the device exhibits these symptoms, see our troubleshooting guide for possible causes before attempting to replace the battery.
The Samsung Series 5 NP540U3C-A02UB uses a 7.4 V rechargeable Lithium Polymer battery. Ensure that such a battery is chosen before attempting a replacement. A compatible battery is provided below.
Wat je nodig hebt
Remove the following screws holding the case together:
6x 4mm Phillips #00 screws.
3x 6mm Phillips #00 screws.
Één andere persoon heeft deze handleiding voltooid.
