Inleiding
In this guide you will be learning how to remove the screen from your Samsung NP5230U4BL laptop. This will enable you to replace a damaged or outdated screen to improve picture quality. Before attempting to remove the screen, be sure to ground yourself with an anti-static wrist strap and have a Philips #00 Screwdriver, as well as a Nylon pry tool on standby. Also carefully follow the given instructions including the cautionary warnings.
Wat je nodig hebt
Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
Press down on the drive with your left thumb and slowly slide it out of place. The drive should slide all the way out of the machine until it is detahced.
On the upper edge of the computer is a spine connecting the base to the screen. The screen is connected to the base by two rectangular, silver hinges located at the right and left edge of the spine.
On each hinge are three, black 1.5 mm screws. Using the Phillips #00 screwdriver, remove these six screws.
