Ga door naar hoofdinhoud
Samsung NP350V5C-T02US RAM Replacement
Wat je nodig hebt
  1. Samsung NP350V5C-T02US RAM Replacement, ODD/HDD/Memory Cover: stap 1, afbeelding 1 van 1
    • Flip the laptop over so that the bottom is facing toward you.
  2. Samsung NP350V5C-T02US RAM Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
  3. Samsung NP350V5C-T02US RAM Replacement: stap 3, afbeelding 1 van 1
    • Using your hand slide the ODD/HDD/Memory panel off in a downward motion.
  4. Samsung NP350V5C-T02US RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Locate the RAM in the lower right hand corner.
  5. Samsung NP350V5C-T02US RAM Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
    • Since there are two RAMs, remove the other one by using the same method.
  6. Samsung NP350V5C-T02US RAM Replacement: stap 6, afbeelding 1 van 1
    • After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
Conclusie
Wanjun Xu
117 Reputatie
1 Handleiding geschreven
Één opmerking
Hello,
Thank you for all of the guides. I was curious if you know what the maximum amount of RAM that this laptop can be upgraded to?
On the Samsung site, it says the max is 8 GB, however the Intel site says 32 GB is the max for the processor.
Could the difference be the motherboard?
Thanks!
Will
Will Terfansky - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 1,011
