Ga door naar hoofdinhoud
Samsung NP300E5C Hard Drive Replacement
Wat je nodig hebt
  1. Samsung NP300E5C Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Hard Drive Replacement: stap 2, afbeelding 1 van 3 Samsung NP300E5C Hard Drive Replacement: stap 2, afbeelding 2 van 3 Samsung NP300E5C Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: stap 3, afbeelding 3 van 3
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
    • Firmly, but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  4. Samsung NP300E5C Hard Drive Replacement: stap 4, afbeelding 1 van 3 Samsung NP300E5C Hard Drive Replacement: stap 4, afbeelding 2 van 3 Samsung NP300E5C Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
    • Gently lift the hard drive up, however do not remove it.
  5. Samsung NP300E5C Hard Drive Replacement: stap 5, afbeelding 1 van 2 Samsung NP300E5C Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Firmly grasp the base of the connector at the bottom of the hard drive.
    • Gently pull the connector off to free the hard drive.
Conclusie
11 andere personen hebben deze handleiding voltooid.
aliahsan95
937 Reputatie
4 handleidingen geschreven
Baylor, Team 10-13, Williams Fall 2015 Lid van Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
3 Leden
2 opmerkingen
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - Antwoord
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 50
Altijd: 12,382
