Inleiding
If you find that your Samsung ATIV Book 2 has begun to operate slowly or is having issues with blue screens it may be time to replace the RAM. In this guide you will learn to do so.
Wat je nodig hebt
Begin with the laptop lying to its back revealing its underside.
Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
To disengage the latches you must push them gently outwards until a soft click is heard.
If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
Één andere persoon heeft deze handleiding voltooid.
