Ga door naar hoofdinhoud
Samsung NP270E5E-K03US RAM Replacement
Wat je nodig hebt
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung NP270E5E-K03US RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: stap 2, afbeelding 1 van 2 Samsung NP270E5E-K03US RAM Replacement: stap 2, afbeelding 2 van 2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Remove the 4mm screw with a Phillips #0 screwdriver.
  4. Samsung NP270E5E-K03US RAM Replacement: stap 4, afbeelding 1 van 3 Samsung NP270E5E-K03US RAM Replacement: stap 4, afbeelding 2 van 3 Samsung NP270E5E-K03US RAM Replacement: stap 4, afbeelding 3 van 3
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: stap 5, afbeelding 1 van 3 Samsung NP270E5E-K03US RAM Replacement: stap 5, afbeelding 2 van 3 Samsung NP270E5E-K03US RAM Replacement: stap 5, afbeelding 3 van 3
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: stap 6, afbeelding 1 van 1
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kyle Golden
353 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S9-G1, Martin Spring 2017 Lid van UMass Dartmouth, Team S9-G1, Martin Spring 2017
UMASSD-MARTIN-S17S9G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 29
Altijd: 1,120
