Ga door naar hoofdinhoud
Samsung NP270E5E-K03US Internal Fan Replacement
Wat je nodig hebt
  1. Samsung NP270E5E-K03US Internal Fan Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung NP270E5E-K03US Internal Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US Internal Fan Replacement: stap 2, afbeelding 1 van 2 Samsung NP270E5E-K03US Internal Fan Replacement: stap 2, afbeelding 2 van 2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US Internal Fan Replacement, Hard Drive: stap 3, afbeelding 1 van 3 Samsung NP270E5E-K03US Internal Fan Replacement, Hard Drive: stap 3, afbeelding 2 van 3 Samsung NP270E5E-K03US Internal Fan Replacement, Hard Drive: stap 3, afbeelding 3 van 3
    • Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
  4. Samsung NP270E5E-K03US Internal Fan Replacement: stap 4, afbeelding 1 van 2 Samsung NP270E5E-K03US Internal Fan Replacement: stap 4, afbeelding 2 van 2
    • Locate the gray hard drive cover, and remove the four corner 3.5mm screws.
  5. Samsung NP270E5E-K03US Internal Fan Replacement: stap 5, afbeelding 1 van 2 Samsung NP270E5E-K03US Internal Fan Replacement: stap 5, afbeelding 2 van 2
    • Lift the hard drive cover by pulling upwards on the removal handle.
    • You can now remove the hard drive from the laptops housing freeing up space to replace your damaged or broken hard drive with a new hard drive.
  6. Samsung NP270E5E-K03US Internal Fan Replacement, Internal Fan: stap 6, afbeelding 1 van 3 Samsung NP270E5E-K03US Internal Fan Replacement, Internal Fan: stap 6, afbeelding 2 van 3 Samsung NP270E5E-K03US Internal Fan Replacement, Internal Fan: stap 6, afbeelding 3 van 3
    • A single 4 mm hidden screw is located under the rubber grip pad in the top right corner. With the Phillips screw driver, remove the grip pad by popping it out of its space.
    • Remove all seventeen 4 mm screws from the back panel marked in the image.
    • Be careful not to tear the rubber foot hiding the screw.
  7. Samsung NP270E5E-K03US Internal Fan Replacement: stap 7, afbeelding 1 van 3 Samsung NP270E5E-K03US Internal Fan Replacement: stap 7, afbeelding 2 van 3 Samsung NP270E5E-K03US Internal Fan Replacement: stap 7, afbeelding 3 van 3
    • Use an opening tool to pop out the back panel from the laptop. Start at the back corners shimmy the opening tool around all edges of laptop before the panel comes loose.
    • This is a slow process, do not attempt to force the entire panel open before making sure you have pried the edges around the entire laptop.
  8. Samsung NP270E5E-K03US Internal Fan Replacement: stap 8, afbeelding 1 van 3 Samsung NP270E5E-K03US Internal Fan Replacement: stap 8, afbeelding 2 van 3 Samsung NP270E5E-K03US Internal Fan Replacement: stap 8, afbeelding 3 van 3
    • Take off the back panel and move it away from the work space.
    • Remove the two 4 mm screws holding the fan in place.
    • Make sure you are keeping all of the screws gathered in a safe place where they will not get lost.
  9. Samsung NP270E5E-K03US Internal Fan Replacement: stap 9, afbeelding 1 van 3 Samsung NP270E5E-K03US Internal Fan Replacement: stap 9, afbeelding 2 van 3 Samsung NP270E5E-K03US Internal Fan Replacement: stap 9, afbeelding 3 van 3
    • Locate the white cable connecting the fan to the motherboard. Unclip the cable from the motherboard.
    • The fan is now free from the laptop and can be wiggled free / removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler
177 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S9-G1, Martin Spring 2017 Lid van UMass Dartmouth, Team S9-G1, Martin Spring 2017
UMASSD-MARTIN-S17S9G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 24
Altijd: 1,299
