Ga door naar hoofdinhoud
Samsung NP-R540-JA09US Front Panel Replacement
Wat je nodig hebt
  1. Samsung NP-R540-JA09US Front Panel Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US Front Panel Replacement: stap 2, afbeelding 1 van 1
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US Front Panel Replacement: stap 3, afbeelding 1 van 2 Samsung NP-R540-JA09US Front Panel Replacement: stap 3, afbeelding 2 van 2
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US Front Panel Replacement, Optical Drive: stap 4, afbeelding 1 van 1
    • Remove securing screw with the PH0 head.
  5. Samsung NP-R540-JA09US Front Panel Replacement: stap 5, afbeelding 1 van 1
    • Slide the optical drive out and remove it from the device.
  6. Samsung NP-R540-JA09US Front Panel Replacement, Keyboard: stap 6, afbeelding 1 van 1
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. Samsung NP-R540-JA09US Front Panel Replacement: stap 8, afbeelding 1 van 1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. Samsung NP-R540-JA09US Front Panel Replacement: stap 9, afbeelding 1 van 2 Samsung NP-R540-JA09US Front Panel Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the keyboard cable from the motherboard.
  9. Samsung NP-R540-JA09US Front Panel Replacement, Front Panel: stap 10, afbeelding 1 van 1
    • Remove the two screws with a Phillips #00 screwdriver.
  10. Samsung NP-R540-JA09US Front Panel Replacement: stap 11, afbeelding 1 van 1
    • Remove the highlighted screws with a Phillips #0 Screwdriver.
  11. Samsung NP-R540-JA09US Front Panel Replacement: stap 12, afbeelding 1 van 3 Samsung NP-R540-JA09US Front Panel Replacement: stap 12, afbeelding 2 van 3 Samsung NP-R540-JA09US Front Panel Replacement: stap 12, afbeelding 3 van 3
    • Pry the front panel away from the base with an Opening Tool.
  12. Samsung NP-R540-JA09US Front Panel Replacement: stap 13, afbeelding 1 van 2 Samsung NP-R540-JA09US Front Panel Replacement: stap 13, afbeelding 2 van 2
    • Disconnect the speaker wire from the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 15
Altijd: 490
