Inleiding
You will need to remove the back plate of the netbook to access the hard drive. This is easily done by following the back removal guide.
Wat je nodig hebt
Locate the external battery on the bottom side of the device.
Locate the tab on the right side of the battery.
Shift the tab to the left.
Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
Locate the hard drive.
Remove the one 3.93 mm screw holding the hard drive in place using a PH1 screw bit.
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thanks for your kindness.
Where can I get the screws from
