Ga door naar hoofdinhoud
Samsung NP-N102S-B05PH Speaker Replacement
Wat je nodig hebt
  1. Samsung NP-N102S-B05PH Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 Samsung NP-N102S-B05PH Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Place the laptop face-down on a stable surface.
    • Remove the nine 6.5mm Phillips #0 screws shown.
    • Use the blue opening tool to gently pry the back of the laptop off of the body.
  2. Samsung NP-N102S-B05PH Speaker Replacement: stap 2, afbeelding 1 van 3 Samsung NP-N102S-B05PH Speaker Replacement: stap 2, afbeelding 2 van 3 Samsung NP-N102S-B05PH Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the six 4.5mm screws holding the motherboard to the case.
  3. Samsung NP-N102S-B05PH Speaker Replacement: stap 3, afbeelding 1 van 2 Samsung NP-N102S-B05PH Speaker Replacement: stap 3, afbeelding 2 van 2
    • Use the spudger to remove the red and black cable located above the speaker from it's connector.
    • Also using the spudger, remove the small ribbon cable located a the bottom of the motherboard, towards the middle.
    • Fold the motherboard back, using the computer hinge as the axis of rotation. The motherboard will still be attached to the case by a few wires.
  4. Samsung NP-N102S-B05PH Speaker Replacement: stap 4, afbeelding 1 van 1
    • Gently unhook the red and black wires from the plastic clips holding them to the case. This can be done with only your fingers.
  5. Samsung NP-N102S-B05PH Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using the spudger, lift the speaker up and out of it's holder, as shown. The yellow plastic tape should peel off as well.
Conclusie
Lennon Grimm
247 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-4, Nance Fall 2016 Lid van USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 1,062
