Ga door naar hoofdinhoud
Samsung NP-N102S-B05PH Hard Drive Replacement
Wat je nodig hebt
  1. Samsung NP-N102S-B05PH Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Before replacing a hard drive, have a backup of original files if files are needed to be recovered afterward.
    • Power down your laptop, and position the laptop with the bottom cover facing upwards.
  2. Samsung NP-N102S-B05PH Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the nine 6.5 mm screws.
  3. Samsung NP-N102S-B05PH Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Use an opening to pry off the bottom cover, clips.
    • Potential for device damage. Before proceeding, be sure to be grounded, as existing static can be transferred and cause significant damage to the device. Wear an anti-static wristband for additional protection.
  4. Samsung NP-N102S-B05PH Hard Drive Replacement: stap 4, afbeelding 1 van 3 Samsung NP-N102S-B05PH Hard Drive Replacement: stap 4, afbeelding 2 van 3 Samsung NP-N102S-B05PH Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the four 4.5 mm bracket screws holding the hard drive onto the motherboard.
    • Take care not to remove the screws holding the bracket to the motherboard, as you will need that bracket to attach the next hard drive.
  5. Samsung NP-N102S-B05PH Hard Drive Replacement: stap 5, afbeelding 1 van 3 Samsung NP-N102S-B05PH Hard Drive Replacement: stap 5, afbeelding 2 van 3 Samsung NP-N102S-B05PH Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Lift the hard drive up and gently pull off the SATA cable that is currently connected to the board.
    • The hard drive is now fully removed from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Daniel Rudzik
349 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-4, Nance Fall 2016 Lid van USF Tampa, Team 2-4, Nance Fall 2016
USFT-NANCE-F16S2G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 1,608
