Ga door naar hoofdinhoud
Samsung NP-130-JA01US Keyboard Replacement
Wat je nodig hebt
  1. Samsung NP-130-JA01US Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charger cable from the computer.
    • Failure to disconnect the charger cable from the computer could result in an electric shock.
    • Flip the computer over so the underside is facing up.
  2. Samsung NP-130-JA01US Keyboard Replacement: stap 2, afbeelding 1 van 2 Samsung NP-130-JA01US Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the left and right slider buttons fully away from each other.
  3. Samsung NP-130-JA01US Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery out of the computer.
  4. Samsung NP-130-JA01US Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Samsung NP-130-JA01US Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Using a Phillips 1 screwdriver carefully remove all 12 screws of the back cover.
    • The screws are Phillips 1 (PH 1) with a length of 60 millimeters (mm)
    • Do not force the screwdriver as you might damage the screws.
  5. Samsung NP-130-JA01US Keyboard Replacement: stap 5, afbeelding 1 van 3 Samsung NP-130-JA01US Keyboard Replacement: stap 5, afbeelding 2 van 3 Samsung NP-130-JA01US Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Flip the computer and open the front cover so that the screen is looking at you.
    • Using a Metal Spudger and your dominant hand, carefully separate the keyboard from the computer frame.
    • Do not force the keyboard out, it should come out easily with the help of the Metal Spudger
  6. Samsung NP-130-JA01US Keyboard Replacement: stap 6, afbeelding 1 van 3 Samsung NP-130-JA01US Keyboard Replacement: stap 6, afbeelding 2 van 3 Samsung NP-130-JA01US Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Flip the keyboard over.
    • Notice the lock mechanism (marked in red) that holds the cables to the computer.
    • With your fingers, flip the mechanism over before pulling the cables out.
    • Second picture shows the unlocked position.
    • Carefully pull the cables out of the computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alejandro Guerra Piol
319 Reputatie
2 handleidingen geschreven
USF Tampa, Team 9-6, Lacy Fall 2016 Lid van USF Tampa, Team 9-6, Lacy Fall 2016
USFT-LACY-F16S9G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 308
