Ga door naar hoofdinhoud
Samsung Mythic SGH-a897 Speaker Replacement
Wat je nodig hebt
  1. Samsung Mythic SGH-a897 Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Speaker Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 Samsung Mythic SGH-a897 Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Conclusie
Morgan Yost
46 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-1, Regan Spring 2013 Lid van Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 253
