Ga door naar hoofdinhoud
Samsung Mythic SGH-a897 LCD Replacement
Wat je nodig hebt
  1. Samsung Mythic SGH-a897 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 LCD Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 LCD Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 LCD Replacement: stap 4, afbeelding 1 van 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 LCD Replacement, Camera: stap 5, afbeelding 1 van 2 Samsung Mythic SGH-a897 LCD Replacement, Camera: stap 5, afbeelding 2 van 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 LCD Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 LCD Replacement: stap 7, afbeelding 1 van 2 Samsung Mythic SGH-a897 LCD Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 LCD Replacement: stap 8, afbeelding 1 van 1
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 LCD Replacement: stap 9, afbeelding 1 van 2 Samsung Mythic SGH-a897 LCD Replacement: stap 9, afbeelding 2 van 2
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 LCD Replacement: stap 10, afbeelding 1 van 2 Samsung Mythic SGH-a897 LCD Replacement: stap 10, afbeelding 2 van 2
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 LCD Replacement: stap 11, afbeelding 1 van 1
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 LCD Replacement: stap 12, afbeelding 1 van 2 Samsung Mythic SGH-a897 LCD Replacement: stap 12, afbeelding 2 van 2
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 LCD Replacement: stap 13, afbeelding 1 van 2 Samsung Mythic SGH-a897 LCD Replacement: stap 13, afbeelding 2 van 2
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
  14. Samsung Mythic SGH-a897 LCD Replacement, LCD: stap 14, afbeelding 1 van 2 Samsung Mythic SGH-a897 LCD Replacement, LCD: stap 14, afbeelding 2 van 2
    • Hold the phone by the black plastic at the ends and gently bend them down so that the middle of the phone is the highest point. Apply pressure slowly until the grey portion pops off.
  15. Samsung Mythic SGH-a897 LCD Replacement: stap 15, afbeelding 1 van 3 Samsung Mythic SGH-a897 LCD Replacement: stap 15, afbeelding 2 van 3 Samsung Mythic SGH-a897 LCD Replacement: stap 15, afbeelding 3 van 3
    Koop
    • Insert the tweezers into the hole to wedge them between the LCD and grey plastic.
    • Once under the LCD, slide the tweezers around the three silver edges until the entire display lifts from the grey plastic.
Conclusie
Morgan Yost
46 Reputatie
6 handleidingen geschreven
Cal Poly, Team 17-1, Regan Spring 2013 Lid van Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 2,212
