Ga door naar hoofdinhoud
Samsung Mythic SGH-a897 Ear Speaker Replacement
Wat je nodig hebt
  1. Samsung Mythic SGH-a897 Ear Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 2, afbeelding 1 van 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Ear Speaker Replacement, Rear Case: stap 3, afbeelding 1 van 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Ear Speaker Replacement, Camera: stap 5, afbeelding 1 van 2 Samsung Mythic SGH-a897 Ear Speaker Replacement, Camera: stap 5, afbeelding 2 van 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
  6. Samsung Mythic SGH-a897 Ear Speaker Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the two 3.8mm screws.
  7. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 7, afbeelding 1 van 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 7, afbeelding 2 van 2
    • Using tweezers, firmly grip the black lever at the bottom of the motherboard.
    • Use the tweezers to flip the black lever up so that it is upright from the motherboard.
  8. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 8, afbeelding 1 van 1
    • Remove the ZIF cable by carefully using the tweezers to pull the cable straight out.
  9. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 9, afbeelding 1 van 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 9, afbeelding 2 van 2
    • On the right from the lever, use the tweezers to unclip the black connector.
  10. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 10, afbeelding 1 van 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 10, afbeelding 2 van 2
    • Use the tweezers to unclip the orange ribbon cable from the left side of the phone.
  11. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 11, afbeelding 1 van 1
    • Use the tweezers to unclip the other orange ribbon cable along the left side of the phone.
    • Work carefully, as this is a very delicate part of the phone's motherboard that can easily be broken.
  12. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 12, afbeelding 1 van 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 12, afbeelding 2 van 2
    • Using either side of the tweezers, slide a side of the tweezer underneath the red and blue wires and the capacitor.
    • Carefully lift the capacitor away from the phone.
  13. Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 13, afbeelding 1 van 2 Samsung Mythic SGH-a897 Ear Speaker Replacement: stap 13, afbeelding 2 van 2
    • DO NOT remove the motherboard completely. One more clip on the motherboard's backside needs to be removed.
    • Carefully tilt the motherboard up from the back of the phone.
    • Use tweezers to unclip the black connector.
  14. Samsung Mythic SGH-a897 Ear Speaker Replacement, Daughterboard: stap 14, afbeelding 1 van 2 Samsung Mythic SGH-a897 Ear Speaker Replacement, Daughterboard: stap 14, afbeelding 2 van 2
    • Use the tweezers to unclip the connector.
    • Remove the daughterboard.
  15. Samsung Mythic SGH-a897 Ear Speaker Replacement, Ear Speaker: stap 15, afbeelding 1 van 1
    • Use tweezers to unclip the silver connector.
    • Then put pressure on the black latch which is circled to release the speaker.
Conclusie
Collin Gordon
45 Reputatie
3 handleidingen geschreven
Cal Poly, Team 17-1, Regan Spring 2013 Lid van Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 8
Altijd: 238
